This is to ensure that changes made by the copper happens after the beginning of a new scanline to prevents glitches or artifacts on the display
The Amiga's display hardware (the Denise chip) performs its initial setup for a new scanline at the beginning of that line, but there is a small processing delay before the actual pixels are rendered. By waiting for the horizontal position to reach 7, you ensure the Copper is synchronized with the start of a new scanline, giving the system enough time to prepare the new line.
ok thanks, so the most likely thing i found i think is this one:
The time-slot allocation per horizontal line is:
4 cycles for memory refresh
3 cycles for disk DMA
4 cycles for audio DMA (2 bytes per channel)
16 cycles for sprite DMA (2 words per channel)
80 cycles for bitplane DMA (even- or odd-numbered slots)
so i imagine that the "glitch" happening when waiting for horizontal cycles prior to 7 is that if you have to change something visible there, there's no guarantee of it being flicker-less (especially when audio and disk activity can pop in and out).
