Wicher 500i boot menu
  • Thread starter Thread starter acer
  • Replies Replies 2
  • Views Views 274
acer
Croatia
Rijeka
Hi guys. I need little help.
Yesterday i received card and installed in my Amiga.
Holding left mouse button during power on or restarting Amiga should bring Wicher boot menu.
I have tried many times and many ways but i cannot to manage to access menu.
What i am missing or what i am doing wrong?
Also i installed Kickstart 3.1.4 from Hyperion, since i want to install AmigaOS 3.1.4
I can boot in Workbench or start game from floppy or gotek.
HDTools on AmigaOS install disk does not see cd card, but i suppose that IDE controller needs to be activated on Wicher card.
Any idea?
Thanks.
I have a wicher but have never been able to bring up the wicher boot menu using the left mouse button (or any other button for that matter). If I remember correctly you can simply run the wicher install disk for the initial setup and enable HDD from there.
This message i got from creator of card:
"For the WicherBootMenu to work, you must use the LoadModule program. Syntax below
C:LoadModule >NIL: DEVS:WicherBootMenu
This entry should be placed at the beginning of Startup-Sequence file.
WicherBootMenu is not a program, it is a kickstart module so you have to use it for example to create your own kickstart or to load with LoadModule."
I am new in Amiga world so i need to check how to this things with load module etc.
If anyone knows how or have some tips and tricks please free to share :)
Whatever i try i cannot get to recognize CF card when i try to install Amiga OS 3.1.4?
Wicher install disk cannot be run since is asking for install?
I am not noob in computers, but this wicher card i cannot figure how to get to work.
Whole day i am searching internet but cannot find much.
Maybe creator of this card should do some instruction how to use since is not just so simple.
