Just wondering if bad capacitors will make an A3640 not function and therefore computer not boot? Conversely, will A3640 work without capacitors at all like for example some motherboards?
www.amibay.com
FYI, I tripped across this old post below from 2010 in my search for answers, and asked the OP about it. He was kind enough to access his FastMEM and reply and noted that indeed, the card failed with the capacitor failure, and upon replacement it returned to full function. I guess what I'll do is take the capacitors off and pop it in capacitor-less and see what happens. Maybe...I'll open a time warp back to 1994!
Advice needed on A3640 repair - caps orientation
Hiya!!! I have here a good friend's A3640 accelerator: it was working fine, until it needed some reboots to have the amiga boot OK and finally it just stopped working. Naturally I suspect the aging caps... but what about their orientation? I have checked the old ones and they seem OK to me but...www.amibay.com
What do you have against capacitors? Did a gang of hooligans named 'The Impedance Boys' steal your lunch money when you were young?By the way, does anyone know if it is true that Amiga 4000 motherboard will boot up without capacitors?
