Sold Willem EPROM Programmer
  • Thread starter Thread starter mmtremors
  • Replies Replies 8
  • Views Views 3991
mmtremors
Rating - 80%
4   1   0
Germany
Dresden
price 25€ + shipping
1. Dual Power Willem EPROM Programmer
2. DB25 parallel cable
3. USB Power Cable
4. Programmer software
and manual in English on CD
5. Adapter EPROM 16BIT (DIP40)
support : 27C1024 (27C210), 27C2048 (27C2002), 27C4096 (27C4002)
Device types supported
EPROM27C64, 27C128, 27C256, 27C512, 27C010, 27C020, 27C040,27C1001
M27C1001, M27C2001, M27C4001
27C080 (A19) ,M27C801,M87C257
2716(Vpp25V),2732
2764, 27128, 27256, 27512, 27010,
Vpp12.5V or Vpp21VEEPROM28C65,28C64, 28C128, 28C256,28C512, 28C010, 28C020, 28C040
M28C16A/17A (DIP28)
(Adapter or Jumper) 28C16,XLS2816 (DIP24)FLASH Memory28F64, 28F128, 28F256, 28F512,28F010, 28F020
MX26C1000, MX26C2000, MX28F1000, MX28F2000
Am28F256A, Am28F512A, Am28F010A, Am28F020A (New command erase/prog.)
-- intel ---
i28F001BX, 28F004, 28F008, 28F016 FLASH Memory29F64, 29F128,29F256, 29F512,29F010, 29F020, 29F040, 29F080
29F001,29F002, 29F004, 29F008, 29F016, 29F032Serial (I2C) EEPROM
24Cxx 24C02,24C04,24C08,24C16, 85C72, 85C82, 85C92
--- page write ----
24C32,24C64,24C128,24C256,24C512 Microwire EEPROM
<------ Data 8bit -----> (pin 6 ->ORG. [Schematic connect to GND])
93C06, 93C46, 93LC46, 93C56, 93C57,
93C66, 93C76, 93C86 (8bit), AT59C11, AT59C22, AT59C13
CAT35C102, CAT35C104, CAT35C108 (pullup pin7)
<------Data 16bit------> (pin 6 ->NC [No Connect])
93C06A ,93C46X,93C56,93C66,93C76,93C86 (NS) MicroChip PIC16C84, 16F84, 16F84A ,16F627/16F628
12C508/A, 12C509/A, 12CE518, 12CE519, 16C505
16C620 16C621, 16C622, 16CE623, 16CE624, 16CE625, 16C710/711
---ICSP connector----
16F870, 16F871, 16F872, 16F873, 16F874, 16F876, 16F877
PIC16F873A, PIC16F874A, PIC16F876A, PIC16F877AAtmel Flash Memory
(Sector Programming)
(Software Data Protection)AT29C256, AT29C512,AT29C010A, AT29C020, AT29C040,AT29C040A
W29EE512,W29EE011, W29EE012, W29C020(128),W29C040
PH29EE010(W29EE011) ASD AE29F1008 (AT29C010), AE29F2008 (AT29C020)
Ver 0.992 up(DOS). Can run under win9x
(disable prog. CPUIdle or CPUCool)
Atmel Flash Memory
AT49Fxxx (Subset 29Fxxx)
(Byte-by-Byte Programming)
(Software Data Protection) Command seq. 5555/AA, 2AAA/55, 5555/A0
AT49F512, AT49F010, AT49F020, AT49F040
SST39SF010, SST3S9F020 ,SST39SF040
AT49F001,AT49F002 , AT49F008A
Command seq. 555/AA, 2AA/55, 555/A0
Am29F512, Am29F010, Am29F020, Am29F040,HY29F080
29F002, 29F002T, Pm29F002T Serial Peripheral Interface (SPI)
EEPROM Mode0 (0,0)
AT25xxx, W95xxx[Atmel] AT25010,020, 040 (A8-A0)
AT25080, 160, 320, 640, 128, 256 (A15-A0)
[ST] W95010....256, Microchip 25x010 - 25x640 --- Byte programming
25010,25020,25040
--- Page programming
25C080,25C160,25C320,25C640,25C128,25C256,25C512
AT25HP256,AT25HP512
AT25HP1024 (24bit address)
-- CAT64LCxxx (16bit DATA IN/OUT) use Socket 93Cxxx
CAT64LC010, CAT64LC020, CAT64LC040
Atmel EEPROM (page prog.)
(Software Data Protection)AT28C256, AT28C010, AT28C040 Nonvaltile SRAM (DS12xx)DS1220,DS1225Y, DS1230Y/AB, DS1245Y/AB, DS1249Y/AB static RAM (Test RAM)6116, 6264, 62256, 62512, 628128 EPROM winbond,SST
Electrical Erase ChipW27E512, W27E010, W27C010, W27C020, W27C040
SST27SF256, SST27SF512, SST27SF010, SST27SF020
MX26C4000
Vcc = 3.3-3.6V SST37VF512, SST37VF010, SST37VF020, SST37VF040Flash Memory SST,Sanyo SST28SF040A ,LE28F4001
Adapters
Atmel AT89Cxx (MCS-51)
Adapter 32pin to MCS-51Atmel Auto Setect
AT89C51,52,55, AT89LV51,52,55
AT89S8252 (8K+2K), AT89S53, AT89LS8252,AT89LS53
AT89C1051,AT89C2051,AT89C4051 (20pin)
AT89C51RC (32KB), AT89C55WD (6.2V)
Intel Auto Select
i87C51, i87C51FA, i87C51FB
i8xC51,i8xC52,i8xC54,i8xC58 (tWP = 100uS*25 Pulse)Atmel AVR 8-bit RISC AT90Sxxx
(Parallel programming)
Adapter 32pin to MCS-51 (read,write,erase,verify,checkempty,Lockbits ,Fusebits) [Flash memory/EEPROM]
AT90S1200,AT90S2313
reference AT90S2313 pin
Function Lockbitread AT90S2313 Errata Sheet.pdfMCS-48,MCS-41
Adapter 32pin to MCS-48/41ROM (read/verify)
P8048AH, P8049AH,P8050AH, P8042AH Vea = 12V
P8041, P8042
OTP (read/verify/Progam)
P8748,P8749H,P8742H Vea = 18V
EPROM (read/verify/Progam)
D8748,D8749,D8742,D8741, D8742 Vea = 18V
FLASH memory 8/16bit
Adapter (TSOP48)Am29F400,Am29F800,29F160,29F320 (read,write byte mode)
HY29F200, HY29F400, HY29F800 , AT49F2048A, AT49F4096A, AT49F8192A
FLASH memory 8/16bit (Vpp12V)
Adapter (TSOP48)
EPROM 16bit (DIP40) (1-4Mbit)
Adapter Eprom 16bit
Eprom only
27C1024 (27C210), 27C2048 (27C2002), 27C4096 (27C4002),
Schematic by Toomas Toots
(read,Program byte mode
by use Resister pull up Data Bus (0xFF), A0 select low or high byte)
EPROM 16bit (DIP42) (4-32Mbit)
Adapter Eprom DIP42
Eprom only
M27C400(DIP40), 27C800, 27C160, 27C322
Adapter (TSOP48LV)29LV200, 29LV400,29LV800,29LV160,29LV320 (read,write byte mode)
Firmware Hub / LPC FLASH
Adapter Firmware Hub/LPC (PLCC32) (PP mode) (3.3V)
-- Firmware Hub
82802AB, 82802AC, AT49LW040, AT49LW080
SST49LF002A, SST49LF003A, SST49LF004A, SST49LF008A
W49V002FA, W39V040FA -- LPC flash
SST49LF020, SST49LF040
W49V002A, W39V040A
P28F002BC
Adapter P28F002BC (DIP40)
BOOT BLOCK FLASH MEMORY
- P28F002BC
Darn, i know i shouldn't say this; but i'm interested! :)
Can i have a shipping quote to Athens Greece please?
Thanks!
PM sent! :)
---------- Post added at 23:31 ---------- Previous post was at 23:01 ----------
Payment sent.. :)
