Works a Hitek Keyboard (A500) on a A1200?
  • Thread starter Thread starter Mad_Maxx
  • Replies Replies 4
  • Views Views 229
Mad_Maxx
Deutschland
Saarland
I know that the connection is different, but is there a chance to use the Hitek Keyboard (mechanical) on an A1200?
I have an old A500 Hitek keyboard in a very good condition and an A1200 with a very „worn“ one.
So I thought - try to connect the best out of two worlds. 😀
Possible?
Compare the matrix on both keyboards. If they are the same and you connect a 31-way ribbon connector from the A500 keyboard to the A1200 mainboard, _and_ if there is nothing hanging on the matrix lines that causes false readings (you might need to remove connection to the A500 decoder) it will work.
It works yes. There are adapters around to easily connect them.
That sounds great. I will try to get one. Thank you. 🙏🏻
