O owen2471 Well-known member AmiBayer Joined Aug 16, 2011 Posts 1,624 Country england Region Sandwell Aug 25, 2025 #1 Hello What is the best way to write c64 games to floppy to use on a 1541 or 1581 drive. Is it possible to write from a device like SDIEC to the 1541 / 81. Thank you
miggymad Current HTTP status code: 418 Assistant AmiBayer Joined Aug 1, 2019 Posts 2,696 Country United Kingdom Region Central Aug 25, 2025 #2 Make sure your 1541 or 1581 is set to device 9 ... Then you can use software like SD2IEC Copy V1.2 https://csdb.dk/release/?id=160461 Mount your .d64 in the SD2IEC then copy to your heart's content
O owen2471 Well-known member AmiBayer Joined Aug 16, 2011 Posts 1,624 Country england Region Sandwell Aug 25, 2025 #3 Brilliant thank you. I haven’t used a real drive in years
