any idea of the requirements, memory useage? install files etc?
thanks![]()
Ok noticed. Thank for the screen grab. I'll fix this for the next releaseThe installer's text looks wrong for me, works fine otherwise
This option already exist. Look in the setup you can choose where X-bEnCh start (Menu/Launcher/cLi)Maybe put an option so x-bench goes directly on launchers list when started (ESC still brings you back to the main menu)
Mmm ... I'm not sure to understand this requestin the launcher list some status line that has in it the name of the lists that the user has set up and when you press TAB it cycles through them?
The option is in the "Startup" tabheh, I never saw the option of where to start![]()
OK !! I already have something planned with this "red line" but this may be combined without problems. That is a really good idea.about the last idea... made a mock-up pic, the last red line now has the list names that the user has set up and pressing TAB to change lists also highlights the name on the red line...
^ glad you liked it
I suspect you would put the search-box there?![]()
