XRGB-mini Framemeister - Pictures
  • Thread starter Thread starter thgill
  • Replies Replies 26
  • Views Views 14071
Hi all
My PAL snes I've modded for multi region and has a 60/50htz switch and PAL/NTSC switch.
Whenever I use the NTSC and 60htz, the picture breaks up and is fuzzy when using the PAL RGB scart cable and the xrgb-mini.
Using s-video direct to a TV it's fine
Any reason why this?
Would I need a NTSC RGB scart cable for this to work properly?
Thanks!
The meister may not be liking the signal your modded pal snes is sending. What does the status say?
Good man! Played with the synch and got all the NTSC games to work without the picture breaking up.
Thanks heaps for your help!
Hi
Seen your pictures, the Mini done great result with 240p res...
I've just got a problem when I plug my A1200 on it, it seems that the blue signal of the rgb transcription is weawing, as if it cut...:unsure:
Testing a A500, and it does the same, but when I plug the two units on my Xrgb-3 the picture is correct...
Did you have an issue like that?
Mine doesn't have any issue like that. Snapshot? Not sure what you mean by weaving and cut. Do you mean there is a distinct lack of blue in the image?
I'll take a capture video and I'll post here
Anyway this A1200 is going on a revision, changing caps and other stuff to set it up :cool:
