I'm thinkning to fit my supra 28 turbo (even my supra ram 8mb in effect..) inside A500 case. Does exist a zorro adapter with flexible cable? soldering a flat cable pin to pin is a possible way? Any suggestion is wery appreciated
While this is possible it would not suggest to solder directly to the expansion slot.
Alternatively you could use a couple of cut-down ISA sockets - some 28AWG wire (40pin IDE Wire) and some heat shrinking.
I would cut the cable to ensure that I had the 86 wires that are required cut to just under 10cm's in length and then ensure that you wire it up correctly - so that you get socket pin for socket pin - test with a multi-meter atleast twice before powering the unit on.
