Closed Zorro slot edge connectors
Astral
NSW Australia
Does anyone have any spare 100pin and/or 86pin zorro slot edge connectors. Perhaps a non-working motherboard as a parts donor, such as an A2000? I would like a few for some hacks I would like to try.
Or even if someone can point me in the direction of an reasonably priced supplier?
:thanks:
Photon
Amiga is Yes. :)
Sweden
Smaland
Re: Zorro slot edge connectors
Haven't done this myself, just passing on the tip.
If you can get hold of some old (REALLY OLD!) PC mobos, you can use two sawed-off ISA slots (if you don't mind desoldering them from the mobo). Or buy new ones, ofc. I haven't found any suppliers of proper Amiga ones, but I haven't looked very hard.
You could always give Amigakit.com a ring and ask.
desiv
work in progress...
Salem Oregon
Photon
Amiga is Yes. :)
Sweden
Smaland
The last one should work, the first one definitely doesn't. The two in the middle - unknown since they don't type wth pin pitch it is! :nuts:
There are two measurements that defines an edge connector, really. Pin pitch and slot height (how thick boards it can accept).
I think that all the ones with the correct pitch, 0.1", should be usable, there's a good tolerance on the height.
The ones with bent pins (not at a 90 degree angle, but the ones that have a "U"-bend on the straight pins) are easy to solder on, not that the hole-mount (straight or 90 degree bend) are annoying.
direktorn
Sweden
Stockholm
Why close a four years old thread? You just woke it up from dead, where it should have stayed. :picard
arnljot
Dad, gamer, nerd, amigian
Oslo
Oslo
Don't be upset with Astral. I asked if he could look over his old threads.
I'm currently doing some sampling to see how well we all do thread housekeeping, mods included ;)
