CDTV Capacitor list
I decided to recap on my CDTV, starting with the CDROM as it has difficulty starting, the front panel as the IR was weak and I am considering the PSU as well. As there doesn't seem to be a comprehensive Capacitor list for the CDTV, the mainboard, CDROM and the PSU I decided to document the values.
After the initial tear-down of the CDTV, I also removed the CDROM PCB, it was a real pain to get to the CDROM PCB, got there eventually. Looks like my CDROM PCB has had quite a bit of rework, an IC was added on a separate board and an additional capacitor was added. See attached images. The capacitors are all low profile/short except two near the power connector, but I have included the sizes in the table. Note there are 3 NON POLAR caps as well.Once I finished the CDROM and Front Panel recap, all initial problems were fixed, non spinning CDROM and weak IR. Note there is a hidden capacitor inside the shielding for the IR on the front panel. Its a pain to get into as you have to bend the metal shield open to replace the capacitor.
CDROM PCB (Note: All Capacitors rated at 85°C)
AmountSpecdiameter x height (mm)Numbers
0.47uF 50v
4 x 5
C115, C329
1
1uF 50v
4 x 5
C321
1
2.2uF 35v NON POLAR
4 x 7
C205
4
2.2uF 50v
4 x 5
C120, C328, C327, C326
8
10uF 16v
4 x 5
C311, rework, C116, C10, C4, C102, C206, C319
1
10uF 10v NON POLAR
4 x 7
C218
1
22uF 6.3v NON POLAR
5 x 7
C208
4
47uF 16v
6 x 5
C305, C204, C219, C322
1
100uF 6.3v
6 x 5
C201
1
220uF 16v
6 x 11
C303
1
330uF 10v
6 x 11
C302
Main PCB - Motherboard version 2.2.1 (
44.7uF 25v5X11C171, C172, C174, C76
510uF 50v
5X11
C163, C162, C155, C85, C14
9
22uF 35v
5X11
C177, C178, C29, C59, C60, C79, C80, C20, C11
47uF 16v
5X11C164, C82
47uF 50v
6x11C152, C23
12
100uF 16v
6x11
C125, C72, C175, C165, C173, C81, C84, C43, C42, C41, C40, C6
1
470uF 10v
8x11C76
3470uF 16v10x12C71, C77, C54
33300uF 10v18x16 (Short and Fat)C2, C61, C69
PSU (all rated 105[FONT=DDG_ProximaNova]°[/FONT]C except C9 at 85[FONT=DDG_ProximaNova]°[/FONT]C)
11uF 50v5x11C111
310uF 50v5x11C8, C112, C103
147uF 50v6x11C10
2100uF 25v6x16C113, C114
1120uF 400v25x30C9
2220uF 25v8x13C104, C106
11000uF 18v10x21C107
11000uF 6.3v10x13C110
21500uF 10v10x30C109, C108
[/QUOTE]
These are all regular (small size) electrolytic caps at 85[FONT=DDG_ProximaNova]°[/FONT]C.
CDTV Front Panel
[TR] [TD]Amount[/TD] [TD]Specification[/TD] [TD]Diameter x height (mm)[/TD] [TD]Numbers[/TD] [/TR] [TR] [TD]2[/TD] [TD]47uF 16v[/TD] [TD]7x6[/TD] [TD]C1, C2[/TD] [/TR] [TR] [TD]1[/TD] [TD]47uF 6.3v[/TD] [TD]4x7[/TD] [TD]CIR[/TD] [/TR]
Once the IR module has been desoldered and removed, carefully lift up the 4 securing tabs inside the shield (green arrows), then you can lift the last piece (blue arrow) covering the IR sensor itself, and finally lift out the module.
Beltalowda
3 min read
2,238
