@Merlin
The A3010 /3020 can run a VGA monitor at 60Hz and does all the frequency conversion on board, it basically has a built in Scandoubler as it will promote most 15Khz modes (including most Games & ELITE) but it will give a letterbox effect on the screen when using a VGA monitor.
You need to check the onboard battery, probably clean it up & then recharge it.
The A3020 has onboard CMOS RAM to hold most system settings & configurations.
To reset the CMOS hold down "R" or "del" whilst switching on & keep it held down until the system boots.
Bob's advice above to set the Monitor mode after you have reset the CMOS is spot on and will need to be done.
at the * or command prompt, enter, *Status and you will get a list of the current configuration.
*Desktop... starts the GUI
*Help... will give you a surprisingly usefull index
*Help Configure... will give a list of the CMOS setting commands.
You can pickup a compatible Acorn mouse from most places & would recomend it over the serial route for 100% compatibility.
The OS is built into ROM, the floppies only have some additional fonts, utilities & applications.
Check the DVD I sent you recently & use Omniflop, which is also on the DVD BTW...
Feel free to call me anytime...
TC
