For Sale A500 IDE adapters, PS/2 mouse adapter, A600 CF adapter
  • Thread starter Thread starter mkl
  • Replies Replies 914
  • Views Views 238211
mkl
Finland
Helsinki
Boards usually supplied without documents. For online information (about kickstart and needed wiring for A500,1000,2000, *) see http://www.mklboards.fi/index.html
(*) CDTV note: Later build use socket pin strips that are a bit taller.
0 ide68k boards available. Price for new boards 50€ including MC68HC000P10 CPU and three 10 cm wires and header pins. Without CPU 45€ (was: without the cpu or the needed 2 wires: 49€.)
1 piece 1GB CF card added: +5€
Shipping 50g 3.65€ Europe, 5.50€ world, registered +16.50€
Slightly elongated Mill-Max brand socket strips with thinner ends plug into mainboard socket and hold cpu pins nicely.
note: yet unchecked if cf adapters like below will fit under a500 keyboard usinh these socket strips in ide68k v4xx
IDE, RAM, 2x 1GB, 68HC000 combo was in this post:
https://www.amibay.com/threads/a500...use-adapter-a600-cf-adapter.7492/post-2508490
Text, pictures and info below maybe outdated - to be revised:
Combo boards: 1 available with all 64 sockets good to hold thin pins of DIP-64 package. 3 others which should be used with adapter for that has thick pins to plug to the combo board with any loose sockets.
IDE + 8MB combo units. 85€ includes also: CF-adapter, 1GB CF (this model 'fixed disk' in HDToolBox), and a CPU of choice: low power new old stock MC68HC000P10 or nos MC68000P12.
Low profile combination for A500 and CDTV(which need cpld reprogrammed)
Shipping 100g 7.50€ Europe, 17.50€ world (registered mail +16.10€ signature, tracking not available to every country)
A number of IDE only boards will be available, 45€
3 RAM boards listed in its thread.
Message: If you have a ram board from me sold before september 14. 2018, your board probably has a malfunctioning RAM controller. It can be fixed by reflashing the CPLD using 6-pin pogo pins and whatever tools you use for Xilinx CPLDs. I have no guide for the process now.
Jedec files and other info:
http://www.mklboards.fi/ram68k
Old pictures and text below:
A2000 can fit separate ram and ide boards stacked. A1000 maybe can fit this stacked set? A1000 needs also KS-ROM adapter to boot.
IDE v425i 50€
0 pcs
Special ide-cf adapter for v4xx for 10 euros or with a v4xx board +5 euros. CF-card will be against the 68000 cpu chip and upside down. Female header or female header with extended pins on other side for connection of other ide bus device. Photo at post #461)
a few: with clearance for v4xx+v6x ram combo. 5 pcs for v4xx without ram board, 0 pcs with clearance for soldered combination ide+ram units, 0 with extended pins.
PCB: 5€ ram v67, 6€ ide v425i
RAM homepage --- www page not available at the moment
8MB v59 and (v6x) (/ with ide board) info: a posting in this same thread.
Ide info below in this post.
(link to old thread for ram )
Might include wires and pin header for int2 and ovr connection.
Pin 20 on ide board has same voltage as cpld, 3.3 volt regulator on v425 board max. 300mA. Some CF adapters have diodes on supply lines, the floppy power input can be used on those (maybe jumper diodes to drop +5v to +3.3v).
Pin 20 can be removed for 80-wire ide cables.
Summary: Plugs to 68K socket, one 40-pin (or 39-pin) connector, "cf" versions also have cf connector
Autoboots using A600's KS-ROM with driver for A600's ide interface (40.063/37.350/37.300)
User needs to connect two (3 in 'cfidecp') signals to Amiga mainboard. A ground wire alongside with signal wires is recommended if the signal wires are not short and following ground trace on amiga pcb to reduce EMI caused by loop inductance.
Cyberfred91's picture of placing a v402 board and cpu on A500 board (R8A1).
(Click the following attach link if the thumbnail doesn't show up)
Some pictures:
A600 cf adapter
-a few pcs: A600 Internal CF-card adapters to IDE connector 15 eur/pce.
Version with also a extension header on top (for hard-disk cable or other adapter) 15€ /pce. Other guide "wing" of cf socket is removed to make space for top header connector.
Mouse adapters
-0 pcs stock Amiga ps/2 mouse adapters with 10pin header, 15€
-upto 0 pcs, without header, long body right angle db9 connector, 20€
PS/2 mouse adapter, Version for Atari ST for sale at Atari ST section.https://www.amibay.com/showthread.p...pters-for-Atari-ST-(-quot-PS2M-quot-firmware)
Other items, Riser cards
Links maybe old - to be updated
LINK 68000 and other cpu:s and electronic components
LINK SOJ RAM to DIP-20 footprint adapters with 1M x 4 drams, A500 surface mount
LINK "riser" cards for 68000 socket, a500 side slot 86-pin edge
LINK adapter board TV-frequency-VGA-in+stereo-in -> SCART-socket-connector-out
LINK PLCC Denise 8373 to DIP-48 socket adapter
LINK 27c4096 to 27c400/800/160, plcc denise to dip socket adapter
LINK 2x 29f040 flash plcc to 27c800 dip socket
LINK ps2 mouse adapter for Atari ST
LINK DCN-2692 (cbm-1581 'clone') v0.15 boards, without cia,wd1772, or rom
Payments
1. Paypal "gift" (send your shipping address by PM) or add fees for (ordinary) paypal.
1B. if sending usd, check that both sending and receiving amounts are in usd (not receiving to euro balance)
2. "Euro transfer" to bank account with IBAN (+ BIC) number (and other needed data.)
Edit: View attachment 2496113View attachment 2496114View attachment 2496115View attachment 2496116View attachment 2496117
I would love some pictures of CFIDE68K V296 mate :)
Btw, is the current version of A600/1200 Internal CF-card adapters to IDE connector, the same as the one I got from you some time ago?
Yes, the a600 adapter is that same version.
can i have a mouse adapter please
pm sent
payment sent
Both completed a600/1200 cf adapters and most mouse adapters sold.
I'll send sold items on wednesday.
@mkl
Does the IDE adaptor work on A2000 with accelerators? Does the clockport interface work? What's the maximum length of the IDE cable that could be used?
Answer for all three questions: Unknown.
Long cable length might bring signal integrity issues, normal IDE-cable is probably ok (about 40 cm). Termination of critical signals and using 80-conductor cables should make long cables work better.
Clockport is not tested by me, I should get some clockport devices to test with.
If A2000 accelerators (in 86-pin slot?) work, I don't know.
Well, so far no progress with it.
Hiya! Got my IDE adapter this morning, it came BLAZING FAST across Europe, nice service, many thanks mkl. Excellent piece of hardware. Leaving feedback now.
hi thanks mkl got my ps/2 mouse adapter yesterday that was fast to me too in uk. work great with a nice new optical ps/2 mouse. leaving feedback now
Feedbacks left.
Around 10 mouse adapters for sale, special offer 4 pcs for 40 euros price including shipping
(About 10 pcs more by next week)
10+ pcs A600/1200 CF-adapters will be completed probably by next week.
10+ CFIDE68K V296 boards during this week.
Feedbacks left.
I have a A500, with A501 memory expansion, and I have some questions about the IDE68K:
Works this IDE68K with 2 devices (HD and CD-ROM, for example)? Can I use the 68010 with the IDE68K? What is the maximum capacity for HDD and partitions?
Could you send a eprom with a kickstart updated for auto-booting?
Feedbacks left.
My friend, i would like to buy one A600/1200 CF-adapter. Would need totall amount including shipping to argentina, since i lost your mails, sorry!
Kind Regards
Sebastian
ad Gavilan: 22 euros total.
Vsargiani: cd-rom is uncertain. I haven't tried cd-rom myself, but a french user reported problem with cd-rom with v295. Earlier, a V100 was confirmed to work with cd-rom.
More:
HDD partitions and size should be as with Amiga model 600. For autoboot you can use
for example the KS-ROM 3.1 V40.063, which is compatible with A500, 600 and 2000.
I'm closing this sale at least for some weeks. I'll complete the remaining ide boards later for sale.
