I've embarked on the journey of building A4000D system, and so far it slowly goes on. I have a few, perhaps easy, questions:
- Storage. What is the easiest/best way to connect CF as a permanent storage? I was looking for a vertical CF adapter, but I also saw some fancy Zorro solutions like Buddha. I'm not looking into I/O benchmarking, need something reliable and easy to set up. I do not have daughter board yet, but have all the components to solder it (not sure when I would have time for that). I can push the daughter board if really needed, but if a non-Zorro solution provides decent speed then I would go for it.
- Floppy. As I understand it, a regular PC floppy drive still would not work with A4000 without hardware mods. I have a working floppy drive from A1200 (Panasonic, probably PC modified), though. Is it compatible with A4000? I have an SFX PSU, and I have a feeling that a custom cable from Molex to Berg is required for such a floppy drive and PSU.
- Gotek. In case it is too much hassle with a floppy drive, I'm fine to go with a Gotek emulator. Would any of them fit? I guess I need an external one, which should fit standard 3.5'' slot. Do I need special IDE and power cables in that case?
- CD-ROM. Are there any compatibility issues or I need some specific model to work? Any specific cables to connect it?
