A1200 with Indivision MK2cr Question
  • Thread starter Thread starter dawnstar
  • Replies Replies 2
  • Views Views 113
dawnstar
United States
California
Okay - I've unloaded my Bank Account on my A1200 -
40.68 Roms, IDE-CF 4GB HD, EasyADF, EasyNet, A1230 Turbo+ w/2x4MB Ram.
Today I installed my new Scan Doubler/Flicker Fixer, the Indivision MK2cr - using BBlank and HighGFX40_6 to use 1024x768 on my NEC Multisync LCD monitor - I get vertical bars on screen.
Can anyone suggest a fix / solution?
Cheers,
Karyn
Are you using VGA or DVI to connect to your monitor? I had similar but horizontal bars with VGA. Over DVI (and now DVI to HDMI) crystal clear image... except...
The typical HighGFX artefacts: https://www.youtube.com/watch?v=d2tqWEFOAkY
They started to happen after the A1200 had warmed up. Then I had the motherboard "fixed"with this resistor hack: https://www.amibay.com/showthread.php?8386-Indivision-Resistor-Hack. Unfortunately it didn't fix it totally. The effect was reversed, only artefacts after turning on the A1200. They dissapear after the computer has warmed up.
PROBLEM SOLVED: A1200 with Indivision MK2cr Question
PROBLEM SOLVED Just bought a new DVI cable - and bing bang boom it works just fine - though the heads up you mentioned are most appreciated.
Karyn
I'm actually using DVI-VGA - was just about to pop off and get a DVI-DVI ...
Are you using VGA or DVI to connect to your monitor? I had similar bur horizontal bars with VGA. Over DVI (and now DVI to HDMI) crystal clear image... except...
And I get the 'vertical bars' from power-on and cycling through all the resolutions - so in other words, it's there from the moment I flick the switch ... Possibly from the conversion from DVI to VGA?
Here's a pic from power-on -
