A2000 cpu slot specs
  • Thread starter Thread starter RetroNinja
  • Replies Replies 3
  • Views Views 564
RetroNinja
USA
Las Vegas, NV
Hello,
Does anyone know the specs for the A2000's CPU slot? I'm referring to the slot to the left of the CPU used for accelerators and such, not the 64 pin CPU socket. So far I have found connectors with these common specs
  • 2x43 or 86 card edge connector
  • pitch = 3.96
  • board thickness = 1.56 (or 1.57)
  • no flange
While these popular/standard specs are probably good, I found nothing definitive for the A2000's. I'm trying to verify specs before I order them. I've also been looking around for details on the slot adapters (right angle or extensions) hoping they would have details but so far no joy. A couple connectors I've found are
  • EDAC 337-086-524-201 on Mouser
  • Vector Electronics 2VH43/1AND5
Manufacturer: EDAC
Product Category: Standard Card Edge Connectors
RoHS: Details
Product: Sockets
Number of Positions: 86 Position
Pitch: 3.96 mm
Board Thickness: 1.57 mm
Mounting Style: Through Hole
Mounting Angle: Vertical
Contact Plating: Gold
Series: 337
Brand: EDAC
Contact Material: Copper Alloy
Current Rating: 3 A
Housing Material: Thermoplastic Polyester
Insulation Resistance: 5000 Mohms
Maximum Operating Temperature: + 105 C
Minimum Operating Temperature: - 40 C
Number of Rows: 2 Row
Product Type: Standard Card Edge Connectors
Hello,
It's 86pin
  • pitch = 3.96
Nope, 2,54mm
1.6mm
  • no flange
Yes
getting these from AliExpress - You can find really great quality connectors there
I found what I thought were the correct ones, ordered them, and they were delivered. They wound up being the exact same model.
WingTat S-86M-2.54-5 Edge Connector Slot
