A2091 LED connector
  • Thread starter Thread starter Domi31320
  • Replies Replies 2
  • Views Views 94
Domi31320
France
Midi-Pyrenees
Dear all,
i have a A2091 with a 4Gb SCSI2SD attached. Everything is working fine but i don't know how to connect the LED from the card to the A2000 front pannel.
I have tried different combinations but none are working.
Help appreciated.
Thank you
Dominique
On mine, the LED connector plug has to go upside down with the empty pin hole overhanging the socket - the black wire ends up on the middle pin and the red one on the pin nearest the front of the case. It is possible my plug has been rearranged in the past.
Thank you for your reply. This does not work for me, either the LED stays off or does not work as expected:
the LED stays on not as bright as it should and blink for disk access...
