stephenfalken
Hi guys.
I have an A2386SX BridgeBoard 16Mhz 20Mhz that i'd like to swap for a decent Amiga 2000 accelerator/RAM.
This card has an extra 1MB of ZIP RAM installed to give the bridgeboard 2MB instead of the usual 1MB, the setup utility picture shows the board detecting there is 2MB on board.
The battery on the board had already leaked when I got the card, so I removed the battery (well, it just fell off when I touched it, actually) and cleaned off as much of the corrosive substance that I could to prevent further damage. I don't really have the time or skill to do any repair work or add a new battery slot.
The card runs and the beeper works as expected, although the missing battery causes the configuration error to show on each cold start. Using a virtual hard file the card boots to MS-DOS, but I have been unable to get the floppy disk access to work.
Only the card itself is supplied. All the software can be found online.
I have included several pictures to show the card booted with the Workbench screen behind. I also added close ups of the battery leaked areas.
Please let me know if you have anything that you would like to swap for this.
Regards
Regards
