So... In my other threads I've chronicled my efforts to replace the caps on my a4K. Finished up last night, hooked up the essentials and powered her up, and no go. So, I'm opening a thread here in the hopes of catching people in the "troubleshooting" section.
Here's what's what:
:sos:
Help? Thanks...!
WhyreByter
Here's what's what:
- It worked OK before I started, albeit with very leaky caps
- Inspection after the caps were off looked OK
- New cap installation has been quadruple-checked for value/direction/alignment
- Only things hooked up are a520 into my TV, power supply, RAM and 3640 (but have tried it with HDD/keyboard/mouse as well)
- What I get is a black screen with no drive activity for a long time (~ 1 minute or more), after which I get a black/grey "moire" pattern on the screen for a split second, and then it goes black again, and my TV loses sync
- After the screen goes off after the pattern, using the CTRL-A-A causes the cycle to restart
- Using the two-mouse-button startup has the same result
- I've tried it without any SIMMs in, with the same result
- I've checked the +5/+12/-12 voltages at various points, and they're all +4.9x/+11.9x/-11.9x
- I've done a thorough visual of the areas that I worked on, and everything looks OK. Plus, the bulk of the work was done in the audio section, or some in the video, which, even if those died shouldn't keep the machine from running the HDD during startup
- I checked the cpu connector, and did notice a couple of pins that looked lightly oxidized, so cleaned them with alcohol, to no avail
:sos:
Help? Thanks...!
WhyreByter
