Got a A4000 motherboard (and daughter board) the other day...
It was in unknown condition as it's been in storage for a while but worked the last time it was used...heh..
The problem I have is that it shows a yellow screen when it boots...
I've tried with both a A3630 and a A3640, both known working in my other Amigas but both display yellow at boot.
No FastRAM and tested with and without the daughter board.
I only have 16MB SIMMs so I'm currently using one of those for ChipRAM but from what I've read they should work, but may only give 1MB Chip. (tried 4 different ones, still yellow)
If I remove the Chip RAM it displays a Green screen as it should...
All chips soldered to the motherboard so no easy way to test those elsewhere. Kickstart 3.0 and Buster -09.
There has been some battery leakage but it doesn't look that bad. I've removed it of course and cleaned the board.
So what could cause a yellow screen at boot?
:help:
:help:
