F flashjazzcat New member Rating - 0% 0 0 0 Joined Mar 29, 2010 Posts 9 Country United Kingdom Region Tyne and Wear Nov 18, 2011 #1 Hi - just obtained an A590 hard disk with no PSU. Could probably fab one up, but I'd be interested in a cheap original if anyone has one on offer. Last edited: Nov 19, 2011
mjnurney we live as we dream. Alone. AmiBayer Rating - 100% 182 0 0 Joined Aug 27, 2010 Posts 9,473 Country england Region Towcester Nov 18, 2011 #2 I'm fairly sure I used an A500 power pack on my a590.
tokyoracer (Not actually from Tokyo). Rating - 100% 173 0 0 Joined Jun 5, 2008 Posts 4,907 Country United Kingdom Region Norfolk Nov 18, 2011 #3 mjnurney said: I'm fairly sure I used an A500 power pack on my a590. Click to expand... Are you sure? The A590 has a round connector like the CD32 and 1541-II PSU's.
mjnurney we live as we dream. Alone. AmiBayer Rating - 100% 182 0 0 Joined Aug 27, 2010 Posts 9,473 Country england Region Towcester Nov 18, 2011 #4 Does it? Mine was the A500 fitting on the a590 I'm sure (ish) It's a simple job to change to plug if the voltages / amps are the same.
FOL Active member Rating - 100% 4 0 0 Joined Apr 20, 2008 Posts 1,077 Country United Kingdom Region Wales Nov 18, 2011 #5 tokyoracer said: mjnurney said: I'm fairly sure I used an A500 power pack on my a590. Click to expand... Are you sure? The A590 has a round connector like the CD32 and 1541-II PSU's. Click to expand... Your correct, the A590 has a round connector. Its the same as a CD32 connector. amigakit sell molex to CD32 connectors.
Merlin Ministry of Retr0bright and Street Judge VIP Rating - 100% 38 0 0 Joined Nov 24, 2007 Posts 15,602 Country UK Region Manchester Nov 18, 2011 #6 If you search on here in AmiOracle, I did post the pinouts for the A590, so that you could use an A500 power supply, as that is what powers mine. Cut the square plug off, wire a 4-pin DIN up and Robert is your Uncle. Edit: Found the pinouts - my thread was over at EAB. You need a four pin DIN plug and it wires up as follows... Pin 1 - Red (+5v) Pin 2 - Black (0v) Pin 3 - NC Pin 4 - Brown (+12v) White (-12v) - not connected - cut this off and tape the cable over, to prevent a short. I hope that this helps. Last edited: Nov 18, 2011
F flashjazzcat New member Rating - 0% 0 0 0 Joined Mar 29, 2010 Posts 9 Country United Kingdom Region Tyne and Wear Nov 18, 2011 #7 Great info - thanks! I guess I'll be looking around for an Amiga PSU to mod now (I have two, but one's stone dead).
F flashjazzcat New member Rating - 0% 0 0 0 Joined Mar 29, 2010 Posts 9 Country United Kingdom Region Tyne and Wear Nov 19, 2011 #8 Found a second PSU for £1.20 on eBay, so once I have that and the DIN 4, I'm good to go. Thanks!
