I also have this problem. Those with solutions please post. Its an awesome keyboard other than the spacebar issue. The 0 key on mine in the number key pad also has this issue. I found if you dont press it all the way on it will work mostly, but the problem comes back as you type. A stronger spring and maybe some graphite key switch lube would help? I also think with use it will start working better. I have some luck with it as I use it feeling a bit better too.I just got my keycaps from steveed and had a chance to fit them. Everything worked out except the spacebar key cap. Seems the outer mount points on the keyboard do not have enough spring to lift the space bar back up. The spacebar just gets stuck in the down position. Not sure if the wire bar beneath is supposed to have tension to spring the bar back up. Just gets stuck in the down position. Anyway, I found a solution that seems to work perfectly. I Just borrowed a couple of springs from a spare Vic-20 keyboard which fit perfectly over the outer mount points under the spacebar and works as I would expect. Keyboard looks fantastic and I can’t wait to get it installed. Let me know if I overlooked something with this spacebar installation![]()
It should physically fit in the case and work with a keyrah for a 1200 but not with a real 500.Declaring interest.
On the off chance that you’re still making these @Aeberbach, I’d be keen to buy an A1200 one from you, and probably the A1200.net one. But here’s my specific situation: do you, or anyone here, know if these would fit within one of the new A500 cases from A1200.net? I’m hoping on using this keyboard with a Keyrah, inside a replica A500 case to use with my daily driver PC for work.
A few VIC 20 spring works perfectly. You can find spare ones on eBay. I just purchased 15 extra springs that I do not plan on using. I can drop a few in the mail if you live in the USA. Just message me directly.I also have this problem. Those with solutions please post. It’s an awesome keyboard other than the spacebar issue. The 0 key on mine in the number key pad also has this issue. I found if you dont press it all the way on it will work mostly, but the problem comes back as you type. A stronger spring and maybe some graphite key switch lube would help? I also think with use it will start working better. I have some luck with it as I use it feeling a bit better too.
This seems like a good deal. I assume keycaps are included? https://amigastore.eu/en/994-mechanical-keyboard-amiga-1200.html#/-/-
Like the nerd idiot I am … I purchased one for my other case
