A600 RGBtoHDMI
  • Thread starter Thread starter ryanm101
  • Replies Replies 2
  • Views Views 610
ryanm101
Rating - 0%
0   0   0
Northern Ireland
Down
I have 3of A600 RGBtoHDMI for sale (these are also advertised on Facebook Amiga group).
Does NOT include the RPi
Comes with 2x 2.54mm header (not soldered).
This will still required soldering to fit to A600 (16 solder points but all fairly simple, it's worth considering removing RF & Composite connectors to provide route out for HDMI)
Image below shows output to 55" 4K screen @ 1080p
IMO this adaptor is a must if you are not using a CRT, I've not tested but I also see no reason why it wouldn't work in parallel for with crt as a capture output.
Prices (includes P&P):
£25 UK
£30 Rest of world
This was a test wireup to verify the display so yes it is a bit messy and its enamelled (magnet) wire not bare copper.
so is this now ECS compatible as those modes where not supported ??
The current version of the board also supports a SuperDenise but only as long as one of the OCS screen modes is used (320x256, 320x512 interlaced, 640x256, 640x512 interlaced).
So I'm afraid not, I honestly don't know if they will ever be supported.
