MikeFishcake
As posted by Jens over on EAB.
Jens on EAB said:I've had several customers in Germany who had stability problems with their ACA1230-28. Three of them have now confirmed that the attached timing fix is perfectly working for them. One feedback is still pending, and one feedback indicates a warranty case.
Chris from AmigaKit confirmed the fix as well, he even did cross-tests by removing and re-applying the caps to really confirm that these are the cause for the stability problems. Thanks for all that work, Chris!
I have snapped pictures and wrote the attached document. Should anyone of you have stability issues with the ACA1230, please check if you have the capacitors E123C and E125C installed. Only remove them if you really have stability problems. By removing them if you don't have any problems, you're likely to introduce timing issues. In other words: If it ain't broke, don't fix it.
Bit nervous about potentially having to hack bits out of my 1200 - what sort of issues are people getting? Is this anything I'm likely to get if I'm just using it as a WHDLoad machine?
Edit: Not that I've confirmed whether I have those particular caps or not yet...
