For Sale AGP to PCI adapters in ENIG finish
  • Thread starter Thread starter bfgmatik
  • Replies Replies 81
  • Views Views 4755
On my A4000 Firebird V I/O is 5V.
Hmmm, OK, but you are probably talking about VIO pins of PCI connector. In my opinion this may be some kind of mistake on Firebird PCB. If logic is 3.3V (and it must be because CPLDs doesn't have any contact with 5V, fully powered from 3.3V at least on v1.1), then VIO should be 3.3V.
BUT:
My adapter doesn't use VIO pins on PCI side. They are left unconnected. 3.3V is routed from 3.3V PCI pins and logic on Firebird v1.1 is 3.3V. So as a result, everything is 3.3V on my adapter. I believe... :)
p.s. Possible reason of 5V on VIO pins on Firebird is PCI specs. As you can see, these slots are 5V-type (they have a 5V-type notch), but still CPLDs are 3.3V.
BUT:
I just got back to home and I'm able to check my Firebird. I confirm that VIO pins of PCI connector are 5V on Firebird v1.1. But these pins are not used by adapter and this doesn't have any influence on adapter operation. 3.3V is taken from 3.3V dedicated pins and whole logic for Firebird, routed to AGP by my adapter is 3.3V.
1x Soldered and tested adapter
(Marked as sold/completed by bfgmatik)
Most of them shipped today, tracking numbers provided. Next will be shipped on Monday. Thanks!
Item received, fast delivery ;) and very well packaged and positive feedback left.
Merci
(y) : Adapter tested on Asus P5K motherboard with Xeon and AGP ATI Rage Pro
Declaring interest in 2 soldered adapters.
Declaring interest in 1 soldered adapters.
  1. torsti76
  2. Karibou
  3. A4k060
  4. roko
  5. RandomInexperiencedGuy
  6. saft6luck
  7. Hirsch
  8. daver
  9. loupsifer
  10. Ollis
  11. St233t
  12. PainDictator
  13. cyberms
  14. DocLeisure
  15. Puppetmaster
  16. zopacepin
  17. torsti76
  18. costner460
  19. Timtheloon
  20. Hannibal
  21. Vasilii
  22. gewse2k
  23. ARKHAAN
  24. Coolfx
  25. mvickers03
  26. Serastros
  27. Evillord68
  28. Fidelware
  29. nicholas.j.henning
  30. dadstoy
  31. tommytamsen
