Ami_Junki was looking for someone in the UK to check over his machines and replace the Caps. I volunteered and am going to use this thread to document my progress.
Firstly the package, just the original box wrapped in a bin liner. Both machines inside were well wrapped in bubble wrap and in good shape though.
The 500 fires up to the 1.3 kickstart screen, so all working fine.
A check of the general condition shows it's in pretty good shape on the outside, minimal yellowing.
On taking it apart there appears to be some sort of residue all over the keyboard plate, I'll be giving that a clean up later.
Stripping it down to the motherboard reveals that there are no nasty surprises, it all seems in order and Ami_Junki gets on and orders a set of capacitors for a Rev 6a motherboard from Cosmo on his thread.
These turned up this morning and it was time to get going. The capacitors are as follows:
location, original, replacement
c303, 22uf 35v, 22uf 63v
c304, 22uf 35v, 22uf 63v
c306, 10uf 35v, 10uf 50v
c307, 470uf 16v, 470uf 16v
c324, 22uf 35v, 22uf 63v
c334, 22uf 35v, 22uf 63v
c401, 3300uf 10v, 3300uf 10v
c402, 3300uf 10v, 3300uf 10v
c712, 10uf 35v, 10uf 50v
c811, 100uf 16v, 100uf 35v
c812, 100uf 16v, 100uf 35v
c813, 100uf 16v, 100uf 35v
c814, 100uf 16v, 100uf 35v
c815, 100uf 16v, 100uf 35v
c816, 100uf 16v, 100uf 35v
c821, 47uf 16v, 47uf 50v
c822, 47uf 16v, 47uf 50v
I removed the original caps, using snips at first and then generous amounts of flux and hot air was called in to finish off the job. This is a time consuming job, as they are connected to the ground which acts as a giant heatsink so patience is a must.
With all the caps removed it was time to solder in the replacements. If you're doing this yourself, take care to check the polarity. Put them in place, and then check again before soldering. The polarity is marked on the motherboard which is very useful. Again this took a bit of time, but you can't really rush this job.
Once they were all in place and soldered, it was time to clean up and check that we still have a working system.
That is a result, and once I reassemble the whole machine I shall give it a full work out and make sure there are no problems.
Once she is fully re-assembled and tested, it will be time to start on the 1200.
