Amiga 1200 D-SUB SCSI backplate dimensions
  • Thread starter Thread starter protek
  • Replies Replies 3
  • Views Views 1084
protek
Finland
Oulu, Pohjois-Pohjanmaa
Is someone able to provide me the dimensions of the A1200 D-SUB SCSI backplate and the orientation of the securing screw hole?
Thanks!
do you mean the plate for the blizzards?
if so thats easy to work out,its a db 25 the L plate fits the hole behind the floppy,the fixing hole to fix it to the case is the plastic lug under the floppy...
you can easily work out the dimensions from that.
Thanks, Roy! That's actually the better choice as I'm not planning to do an exact replica of the original bracket. I do need to work out the dimensions of some D-connector openings, though.
