Recently I have soldered an Amiga 2000 reproduction board by Floppie209. Unfortunately, I have had difficulty sourcing a case for it. Eventually, I found something on eBay, although in poor condition (broken mounting poles in front bezel and drilled holes with toggle switches installed).
I decided to create my own case using original measurements. To test the fit, I used a second, unpopulated board. I made a mounting bracket for Zorro cards, which I will have to correct in some ways (expand the groove which boards lean against and think of an appropriate insulation material), however I don't think this is necessary for the A2000, except for transportation.
I intended to use a scandoubler, the PCB of which you can see, which I also created a rear bracket for. I heard that PAL is not ideal, NTSC runs comparably better - does anyone have an opinion on this topic?
I have, to the best of my ability, tried to make the case as similar to the original as possible. Unfortunately, I do not know how long it will take me to finish this project (I would like to first populate the case how I want).
More pictures can be found here:https://drive.google.com/drive/folders/1jQUMemwNLoX451FqDRstYwTCjELtxH5I?usp=sharing
