Amiga 23-pin to VGA adapters fully compatible with the original Commodore adapters but I added some useful features not present in the original ones.
IT IS NOT A FLICKER FIXER OR A SCANDOUBLER which costs much more.
Availability: 2 PCS with 23-pin D-SUB connectors.
Price is 12 EUR plus P&P most country not tracked about 5 EUR.
Payment sent by IBAN bank transfer.
- Real 23-pin D-SUB Amiga video female connector.
- Totally buffered H and V outputs via a specialized buffer IC.
- Switching of the H&V sync polarity via jumper pads totally separated (default as original Commodore).
- 3mm LED power supply status (no +5V is present at video connector if the LED is turned off).
- RGB signals interconnected directly between connectors (no limiting capacitors).
- H&V outputs short-circuit protected.
- Small PCB, approx. 4x3 cm.
