A2000 test install of my 8mb/IDE board
Hi All...
I finally got a chance to unpack my A2000 and test it out. It's the first time i ever touched one. there were a few boards in there so i had to remove them, one was a 3.5" HDD board and the other was expansion ram, I never give them a chance to see if they worked, i just removed them.
The A2000 itself is a Rev 6.2 board with KS3.1 already in it. I had to check out the A2000 schematics to find oyt the options for connecting the 2 wires from the board and as it happens i got very lucky. (You'll see further down).
Ok, lets show some pictures.
First off, an angled view of the 8mb board in place, wires going to motherboard
Next view is a picture of the board showing the LED cable (Red/Black) that utilizes the A2000's LED. I removed the solder blob from the fastmem board, put in the 2 pin header and away it went
Notice that the Int2 and OVR wire on the fastmem board is actually plugged into the header at the top of the board instead of where it normally is. I added a second header just in case. and it is serendipitous (look it up
Angled view of board in place
Here is how i connected the 2 wires to the motherboard. Using the schematic i found that both required connections are available on the motherboard risers so no soldering to the motherboard required...
Here is how i done it, i sacrificed a video hybrid board by cutting off a small piece so i could make use of the pads...
I then soldered the 2 wires to the cut off part and then pushed it into the CN600 header... Pins 17 and 19 on the header are next to each other on the riser so i could simply push in my cutoff board at pins 17 (OVR) and 19 (Int2). A little bit of hot glue to make it semi permanent and all set.
Notice that the PSU and drive cage is back in place and there is clear space. 2 sets of risers were used for the board to clear the motherboard components
Peekaboo, showing the board below the drive cage
And finally... the boot up
Sysinfo reported...
I just looked up from typing and the cat was sitting on the motherboard while it was turned on... Anyone want a cat, damn thing is in heat too, she won't stop coo'ing
---------- Post added at 19:19 ---------- Previous post was at 19:16 ----------
I sent you a PM and E-mail for two A500 board with 8MB of RAM and IDE.
Could you add me to the list?
Hi I did add you
just never replied sorry.
