I am probably staring at the solution and wanted to ask here!
I recently found an old A600 that was buried in my hoard.
The machine was bought years ago, described as not-working and dead.
I vaguely remember the original kickstart was faulty. I pulled that and just put the machine back into storage.
Until recently I decided to have a closer look (all the fuss regarding buying a re-capped board that was not as described).
I fished through my stuff and found a kickstart 3.X 45.064 rom, in a fit of lazyness I fitted that and found the machine works fine!
But I cannot get any workbench to load up, I have an external gotek fitted and also used some original disks.
Everything works! I can load games, all sorts. I can load things up directly, Protracker from a startup-sequence.
I can load everything but workbench, all I get is a blank window with the bar accross the top!
Amiga test kit reports the whole machine is good!
Is this to do with the rom and I am loading the wrong things hence why I am tripping over?
I am going to find an original kickstart for this machine and get it re-capped.
