The adapter I had been using seemed to stop working :/
I'm wondering if something has gone wrong with the CF card itself, but it still works on a PC...
---------- Post added at 13:36 ---------- Previous post was at 13:09 ----------
Ok, so I have the compact flash adapter plugged into a 2.5inch ide to usb adapter.
Original CF adapter, set to master, takes ages when you click the add HDD button, comes up with the above.
Set to slave, and the red light on the adapter just comes on, and the drive never appears.
New CF adapter, set to master, as above, takes ages, appears as "no media"
Set it to slave, and it appears instantly in the list, still as "no media"
:double
---------- Post added at 15:01 ---------- Previous post was at 13:36 ----------
Tried a different USB to IDE adapter, this time for a 3.5inch drive, which of course, also meant a different IDE to CF adapter again (one that I've never been able to connect to the amiga, due to it being 3.5inch...
Worked perfectly...
So, now I know that usb-ide-cf can in fact work, I'm going to connect this usb-ide adapter to a 3.5-2.5inch ide cable, so I can connect it to the two "bad" ide-cf adapters, and see what happens...
