For Sale Amiga A600 Keyboard Membrane Replacement PCB
  • Thread starter Thread starter solarmon
  • Replies Replies 34
  • Views Views 2185
solarmon
Hampshire
Please declare your interest and then PM me to discuss further.
Sorry, no longer selling/shipping to the US.
For sale:
Amiga A600 Keyboard Membrane Replacement PCB (v1.0)
PCB Colour: Green
PCB Thickness: 0.4mm
PCB Finish: ENIG
Compatible with:
* A600:
- Original Mitsumi 56C471B (Green) membrane - NOTE: CAPS LOCK LED polarity needs to he reversed (bend the CAPS LOCK LED legs the other way)
- 8770-0056 REV E (Blue) membrane
The cost is per item, plus Royal Mail postage from UK. Payment is via PayPal (use Family and Friends, or add fees with Goods and Services).
Please be aware of any additional customs cost you may incur for your country.
There are two options available, with some small discounts available at different quantities:
* DIY Kit:
Comes with:
* 2 x FFC connectors, which requires soldering
* 1 x 15cm FFC flex cable
1 = £19.00 per item
2-3 = £18.50 per item
4-5 = £18.00 per item
* Ready Built:
Comes with:
* 2 x FFC connectors, already soldered
* 1 x 15cm FFC flex cable)
1 = £20.50 per item
2-3 = £20.00 per item
4-5 = £19.50 per item
1 x ready built
(Marked as sold/completed by solarmon)
2 pcs ready build.
2 pcs ready build.
1 ready build.
PM sent
Payment sent for 1 ready built membrane for Amiga 600 and PM sent with shipping details.
I didn't know you have also A600 membranes. 🙈 My friend maybe want one for A1200 and A600 too,i definitely want A600 ready built one too.Just need check which type i have.
Hello Solarmon.
Need one ready built for my new A600 build.
What is the led that need to be bent for the green membraned keboard exactly?
Hello Solarmon.
There are are two version of the A600 keyboard membrane - 'blue' and 'green' versions. Although this first revision (v1.0) of my A600 keyboard membrane PCB supports both types, the CAPS LOCK LED orientation is from the 'blue' membrane. If you have a 'green' membrane keyboard, the CAPS LOCK LED needs to be bent and fitted back the other way.
In the next revision (v1.1) this will be fixed.
declaring interest
(Interest marked as expired by solarmon)
1 x ready built please :)
EDIT: Can I please change this and have two?
