OliverEales
Hereby I sell my Amiga CD32 in revision 4.1, which has the 8-pin MiniDIN connector in which RGB is also fully occupied.
A professional RECAP was carried out on the CD32 in 2019, I still have the invoice.
It comes with an installed TerribleFire TF330 turbo card with full 68030/50 MHz and 64MB FastRam installed.
Together with the Kipper2k riser board, the CD32 also has a DB23 23pin RGB monitor port and a PS2 keyboard port.
(The extensions are under the black cover at the back).
An ESP-32 module is installed on the turbo card, so the CD32 can access the internet via WIFI/WLAN.
In addition to the original, functional power supply unit, there is also a stronger, smaller power supply unit bought here on AmiBay 3 years ago. Both power supplies work.
Also included is a honeypad controller and two PSX-DB9 adapters ( https://retro-commodore.eu/files/do...Hardware/PSX - Amiga-Adapter - Manual-ENG.pdf ).
These allow you to use Playstation2 controllers as Amiga JoyPads or even as a mouse.
Amiga OS 3.5 is installed on the CF card, the system boots from it.
An RGB ( and not only S-VHS ) picture can be output via the enclosed SCART connection cable. Perfect for displaying the Workbench in PAL Hires-Interlace mode and 100Hz on an LED TV.
Furthermore, an Amiga 1200 mouse, a PC PS/2 keyboard, a Playstation2 controller and the USB serial controller and the ESP32 can be programmed to the local WLAN. ( on the PC )
CD32 games from CD also run directly.
The system runs absolutely stable and is perfectly suitable for "living room setups".
*AmigaCD32
*original power supply and stronger accessory power supply
*Kipper 2K riser board with monitor and keyboard connector
*Terrible Fire TF330, 64 MB RAM, 4 CompactFlash card
*ESP-32 module for WLAN with programmer
*2 PSX-DB9 adapters and a Playstation2 controller
*Honeypad Amiga CD32 controller
*Amiga 1200 mouse
*PC keyboard
*original CD32 expansion slot cover
Ask 790 EUR plus P&P
Payment PayPal as gift
Edit: Closing Post because of wrong Forum
*AmigaCD32
*Amiga 1200 mouse
*PC keyboard
