For Sale Amiga EXCALIBUR --> Professional video cable converter from RGB to S-VIDEO & CVBS (PAL & NTSC)
  • Thread starter Thread starter axel81
  • Replies Replies 67
  • Views Views 5067
axel81
Italia
Monza Brianza
Amiga EXCALIBUR
(Video cable converter from RGB to S-Video & CVBS ..PAL & NTSC supported!)
Pre order available
It is already possible to buy the first available pieces with shipping in 5/7 days. As soon as a batch of quantities is available, the "pre-sale" will be replaced by the sale with canonical packaging times of 2 working days :)
What is it?
  • Excalibur is new AMIGA video adapter cable from RGB to S-Video & CVBS!
  • Extreme solution developed inside the original DB23 cover shell. Now you can connect your AMIGA to any TV/monitor that has a SVIDEO or CVBS input (choose the option that's right for you)
  • PAL & NTSC compatible (just choose your version)
  • S-video cable 1mt lenght
  • CVBS cable is real 75Ohm 1mt lenght (check wire section/details)
IMPORTANT NOTICE
  • Video cable converter is made with original & genuine D-Sub DB23 female connector and its cover shell!
  • Project is copy-protected. Development is owned and performed by me. Any reproduction/resale/modification/copying is prohibited and will be prosecuted
With EXCALIBUR you can connect your AMIGA to your TV/monitor with S-video input or CVBS input
Compatible with the following systems:
  • Commodore Amiga A500 / A500 +
  • Commodore Amiga A600 / A600HD
  • Commodore Amiga A1000
  • Commodore Amiga A1200 / A1200HD
  • Commodore Amiga A1500
  • Commodore Amiga A2000
  • Commodore Amiga A3000
  • Commodore Amiga A4000
  • Commodore Amiga CDTV
FINAL NOTES:
  • Cable colors may change in black/white/grey (based on current availability)
  • S-VIDEO and CVBS connectors will be moulded type plastic or metal gold plated (based on current availability)
  • Don't forget that you are buying an exclusive and professional product for your AMIGA
PRICES (Paypal "as friend" without shipping):
PAL VERSION
  • EXCALIBUR CVBS --> 36€
  • EXCALIBUR SVIDEO --> 39€
  • EXCALIBUR CVBS & SVIDEO --> 44€
NTSC VERSION
  • EXCALIBUR CVBS --> 38€
  • EXCALIBUR SVIDEO --> 40€
  • EXCALIBUR CVBS & SVIDEO --> 46€
Edit:
Package received yesterday, great as always.
Positive feedback left.
Thank you too man :cool: ..positive feedback left
In the pal version I would be interested in possible 3 but definitely 2
what is the longest length you could do? Or are we restricted to 1M?
Hi there Tim
do you mean option PAL S-VIDEO or QT2 Excalibur PAL?
The problem is not the cable length but the cables available in the warehouse to be used :cool: (and envelope weight after...it means shipping price)
I check but I think I have a golden metallic Svideo version that I can use to make the 1.5mt S-video cable.. maybe little price difference compared to moulded type (this picture)
Please confirm that the option you are interested in is PAL S-VIDEO and quantity
P.S: I think I'll code the options to make the choice easier...soon
Regards
Oh sorry I veiw Amibay in dark mode and didn't notice the other options when quickly scanning through. @comraider is there away we can tackle this when someone uses a dark text?
It's the Svideo option
What's the difference between the PAL and NTSC cables? The reason I ask, is that I have several Amigas, all are PAL, but I now live in North America, and have an NTSC CRT TV. Just wondering which cable I should use.
PAL or NTSC?
We are talking about analog TV Standard
In U.S.A tv standard is NTSC (525lines/60Hz)
In Europe TV standard is PAL (625lines/50Hz)
So Excalibur PAL with PAL TV
Regards
How come we have to choose either ntsc or pal? No solution for both?
If I have a ntsc amiga but want to use pal software sometimes will a ntsc svideo cable just show black amd white?
In this case PAL/NTSC system requires more space and nothing else could be added inside.
However consider that you are not connecting a "simple Amiga SCART cable"...that is an active converter cable
In other words ..if you have to connect your Amiga to an NTSC monitor it must also be NTSC....you cannot connect it to a standard PAL monitor
Summary:
  • AMIGA PAL --> EXCALIBUR PAL --> MONITOR/TV PAL
  • AMIGA NTSC --> EXCALIBUR NTSC --> MONITOR/TV NTSC
Edit:
In any case, your PAL Amigas must be connected to a standard PAL TV.
Even without this cable you have to use a TV/monitor with the same standard
Thanks axel81. I have 2 sony monitors which can display both ntsc and pal.
If there is any way you can build me 2 ntsc plus pal cables let me know :)
Very interested! Was just looking around for something like this :)
I would like a svideo pal cable, what do i do?
declaring interest in one NTSC version of the adapter and cables assembled fitting Amiga
2k,3k and 4k
PM me for payment thru PAYPAL as friend
