For Sale Amiga VOYAGER --> Professional video converter from RGB to YPbPr (PAL & NTSC)
  • Thread starter Thread starter axel81
  • Replies Replies 42
  • Views Views 2555
Hi, I've started a conversation a few days ago regarding your cable, when you find the time please check it out.
Hi Axel,
I messaged you on Tuesday regarding some issues with the voyager cable and also not had much luck with the VLR adapter.
I’d like to return them for a refund please.
I’ve had luck with one of the adapters I purchased, so will keep that one.
Kind regards
Hi Axel,
Kind regards
PM sent
A brief consideration because it seems alarming to me for those who read :-)
Voyager: I wrote that it was necessary to check the compatibility of the monitor/TV
VLR Upgrade DB23-DB23: I wrote you PM to understand how you connected it
VLR Extreme: I wrote you to understand since you were talking about OSSC between Amiga and Lacie monitor
Hi there
Refund send to your account.
Some clarifications regarding the products as they worked as expected
Voyager YPbPr works as I expected
Tested on all my Amigas and with the three compatible monitors but the colors are really perfect, there is no problem.
The problem is in your "A4000 board built by Kavanoz" that is not compatible and it is not a true and original Amiga A4000 (something different in the RGB level or something else)
DB23-DB23 VLR Upgrade works as I expected
Tested on all my Amigas and works fine
The problem is in your "A4000 board built by Kavanoz" that is not compatible and it is not a true and original Amiga A4000. Original Amiga provides +5VDC on the D-sub 23pin RGB connector...but on your A4000 replica it is not present
Hi there
I have received refund for the voyager. Thank you
I have not received refund for $35.90 for the DB23 cable.
I have purchased DB23 VLR that requires power from the DB23 port elsewhere and these work fine.
Refund for VLR upgrade already sent
