Hey all,
I know many people use the RGB2HDMI solution on the Amiga, so I am sure this issue has reared it's head many times before.
Using RGB2HDMI I get a nice solid stable image for Workbench - running in PAL Hi-Res Laced with quite a bit of overscan. All good. However about a third of the software I run causing the screen to dance about, flicker on and off, and just will not sync. At first I thought these programs were opening NTSC screenmodes which the RGB2HDMI didn't like, but they are not - they are opening PAL screenmodes. Also, I have tried using ModePro to force te same PAL Hi-Res Laced screenmode to rule that out - no difference.
Obviously it is some setting, pixel clock, vsync... SOMETHING that I need to adjust, however I have played around for ages adjusting things and it seems to make no difference at all. I have even tried seveal different monitors to rule that out - they all display the same issues with the same programs.
HELP!
HELP!
