For Sale Amiga VGA Adapter BUFFERED + VERTICAL LINES REMOVER! Made with original DB23F (also for GBS8200/OSSC)
  • Thread starter Thread starter axel81
  • Replies Replies 489
  • Views Views 40383
Yes
If you are not satisfied you can return it.
The only problem remains the "customs" because in case of return I think you have to pay the customs costs..
Edit:
Which model do you have?
Thanks the screen I have is a Dell SE2722H.
I would like to order the VLR, please advise which model is recommended and how to pay.
And a VGA input. I also want to be able to attach my video capture which supports HDMI or VGA.
Be aware, fact that it has SCART input does not mean that it can sync down to 15kHz through VGA port. I tested that on 710MP monitor, older one. So first, check if it can, to avoid disappointment after getting the adapter.
Thanks for the tip. I have looked in the specifications. It can indeed not process 15kHz. Too bad.
Got mine today. Significant difference. On Hi Res Pal it removed almost everything, what is left serves as some sort of scanline effect which is great in games. Hardly noticeable. I can recommend this product.
Great..thank you again for your purchase :cool:
Mine arrived today. Used on my Dell SE2722H screen. I was sceptical… Not now!!
Of course YMMV based on screen.
On my benq bl702a, the VLR adapter was not needed and did nothing when used.
ddni: check how clear is the checkerboard pattern with your adapters (the picture down is how it should look for correct geometry):
Hi Amigoun.
Two photos of my screen. The checkerboard pattern with VLR looks far superior to the standard VGA adapter.
