Amiga VOYAGER
(Video cable converter from RGB to YPbPr..PAL & NTSC supported!)
What is it?
IMPORTANT NOTICE
With VOYAGER you can connect your AMIGA to your TV/monitor with YPbPr
Compatible with the following systems:
TV/Monitor compatibility:
The YPbPr system is not compatible with all monitors/TVs on the market... and of all the systems it is the most "mangy" as it also requires the electronic circuit to be calibrated with precision resistors. If a TV/monitor is not 100% compatible you will have problems with image freezing/strange flashes. So how to do it??
To verify compatibility it is necessary to connect the Monochrome output of the Amiga to the Y input of the monitor/TV and a stable black/white image must be obtained. If so, it means that your monitor/TV is compatible. Or if you already have a compatible monitor/TV that you have checked because you are already using it
VOYAGER PRICE --> 45€
What is it?
- VOYAGER is new AMIGA video adapter cable from RGB to YPbPr!
- Extreme solution developed inside the original DB23 cover shell. Now you can connect your AMIGA to any TV/monitor that has a YPbPr video input
- PAL & NTSC compatible (it means that you can use with your Amiga PAL and TV PAL or Amiga NTSC and TV NTSC)
- Tested 240p, 288p, 576i ,480i resolutions (15KHz NTSC and PAL). Please remember that this adapter does not upscale your video.! Sync is sent 1:1 to your TV/monitor.
- After several visual comparisons I can state that the quality is superior to the classic RGB connection (example SCART cable)
IMPORTANT NOTICE
- Video cable converter is made with original & genuine D-Sub DB23 female connector and its cover shell!
- YPbPr connectors are moulded grade (green...blue...red)
- Don't forget that you are buying an exclusive and professional product for your AMIGA
- Project is copy-protected. Development is owned and performed by me. I spent many weeks optimizing it and obtaining this result..Any reproduction/resale/modification/copying is not allowed/prohibited
- Commodore Amiga A500 / A500 +
- Commodore Amiga A600 / A600HD
- Commodore Amiga A1000
- Commodore Amiga A1200 / A1200HD
- Commodore Amiga A1500
- Commodore Amiga A2000
- Commodore Amiga A3000
- Commodore Amiga A4000
- Commodore Amiga CDTV
- Commodore Amiga CD32 (if you have video ouput expansionwith DB23F)
