Hello,
As per the subject. I have now properly installed AmigaOS 4.1FE on my CyberPPC 060/PPC setup.
Currently using an ACILL A4KD motherboard with Rev B recapped Daughterboard with the following setup:
Phase 5 Cybervision 64/3D
X-Surf 100 Z3
FastATA MK V Z3 IDE to SD
Individual Computers Big-RAM Plus 256MB
I currently have a SCSI2SD, SCSI multicard reader on the CYBPPC SCSI. Although I have AmigaOS 3.2.3 with AmigaOS 4.1 FE on a IDE SD adapter which will see the Multi-card.
So, my plan was to look at adding another SCSI card. But, as I have found out with owning both a FastLane Z3 rev 2.4 and a Re-Created A4091. Amiga OS 4.1FE will fail to boot? Works fine on AmigaOS 3.2.3.
Yes the CSPPC SCSI functions and have read that Hyperion use there own cybpppc.device and ignores the inbuilt CYBPPC.device on ROM as well as any PROM settings via the ‘ESC’ early menu.
So apart from a FastATA MK VI and VII which are AOS 4.1 certified to work. A majority of Z3 RTG cards and most NICs.
What else (Especially SCSI Zorro cards) work on Amiga OS 4.1 FE Classic?
Cheers
X-Surf 100 Z3
Cheers
