Upgraded with this guide - >
http://wordpress.hertell.nu/?p=474
Current situation is that card works if remove resistor like Chucky guide says ( OVERCLOCKING TO 80MHz) and put jumper to 040 position.
But in this case CPU will be 66mhz and memory always half of it. 1:0,5
Fastest working 1:1 speed for CPU and memory is 40mhz. It doesn't work even without memory module higher frequencies. So no memory problem.
Fastest working 1:1 speed for CPU and memory is 40mhz. It doesn’t work even without memory module higher frequencies. So no memory problem.I don’t have rev 6 68060 cpus, so I would like to get it work with 66mhz CPU:Ram 1:1, or even 50mhz, but fastest working 1:1 speed is 40mhz
Any hints and tips?
Any hints and tips?
