Closed AV Modded PC Engine with Everdrive
scrappysphinx
Confused retro man
Nottingham
Hi all, i have for sale my pc engine with turbo everdrive.
The RF port has been removed and a female usb socket has been hot glued in its place and wired up for composite video with stereo audio.
Its not the neatest but i used what i had to hand at the time so i didn't have to use RF :lol:
The everdrive is a v1.2 works fine, a 2gb micro sd card will be included but it won't have any roms on it.
Console has started to yellow but not heavily, controller is quite yellowed. Power supply and USB-AV cable are included.
A console ready to play :)
Looking for £90 (was £100) plus p&p
Decided to tidy this up a little. The usb port has been removed and a.megadrive 2 9 pin din socket was fitted. Now supplied with megadrive 2 available cable. This also makes rgb modding this unit very easy as all you need to do is buy an RGB amp and fit it.
Sent from my ONEPLUS A3003 using Tapatalk
It's the standard 2 button pc engine controller. It's quite a bit more yellowed than the pc engine itself.
Removing from sale and closing thread due to acquiring an RGB Amp so will be fitting that shortly.
