markm
This is for the BenONE PCI card with the BenADDA daughter card (with the Xc2V3000 part on it). It has a USB adapter on it but I also have an ethernet one (no idea if it can be used instead but it certainly looks compatible.
I have no idea if it still works and don't know how to use it (this is from a recent clear out) but I did manage to find a doc for it: http://www.es.ele.tue.nl/mininoc/doc/xdsp_ug.pdf
A bit of googling and found this from 2004 (though the board was built in 2002):
BenADDA: 14-Bit, ADC and (DAC?)
Nallatech
FEATURES
Asking £20 + postage or sensible offers. This is just the boards as pictured below - no cables etc.
Nallatech
FEATURES
- Onboard Xilinx Virtex-II FPGA
- Various FPGA device packages, sizes, and speed-grade options available
- Two independent analog capture channels
- 2x 14-bit ADC resolution, up to 105 MSps per channel sampling rate
- Two independent channels to extract analog data
- 2x 14-bit DAC resolution, 160 MSps per channel sampling rate
- Up to 8 MB of ZBT SRAM memory in two independent banks
- Nallatech ZBT SRAM interfacing IP core available
- Multiple clocking options: internal and external
