According to that link, the Appolo 1240/30 is slightly faster than a Blizzard 1230/50, so an 1240/25 will be very close in performance to a 1230/50.
Considering the heat problems of the 040 (forgot all about that!) it might not be such a good idea after all...
I reviewed the graph and the numbers a little strange in all truth - besides that theres lots to consider here other than in sheer raw dhrystones by SysInfo (dhrystones are not MIPS persay but close enough)
9,500 - Blizzard 030@50
18,600 - Apollo 040@25
26,000 - Apollo 040@40
Its best to note here that SysInfo wont make use of the secondary ALU on the 060 as such it will only see a little over 38,000 Dhrystones @ 50hz- to give you the manufactures statement (a 66mhz 060 will perform over 100 MIPS) theres lots in this bench testing m'larky -
Alas that lot is only half the story - the next (and biggest) part is the memory handling speeds (fast 2 chip & chip 3 fast), the integer engine(s) and the all inportant (you forgot it) FPU (MFLOPS) the 030 needs an FPU the 040 has an FPU engine built in, and when you get hold of "HSMaths" the 040/060 fpu engine better than an 68882 of the same frequency
in a nutshell 95% of Demo's - like games are written to run on less than an 030@50 its only those power demo's and apps that demand the horse power sir
talking about heat - an 040@25 whops out about the same as an 030@50, due to the Apollo 040 design, the cpu unit is in a *dead* air space as such needs an low-powered active cooling unit - in retrospect the blizzard 040 is in the opposite orientation as such dissapates it heat differently and as there is a small air gap usually just a heatsink is require.
Its important to note that different revisions of each CPU exist, as such MC units run much cooler than XC units - infact the latest generation of 040 CPU's run cool to the touch at 40mhz.
so whats good for you - well this is where you need to rationalize what you want. personally I would plum for the A4000 - 040@25 or higher - the general performace gain is much better than a 50mhz 030
compatability on the other hand might be a factor, however I have not really experieneced these *040 or 060 issues* i read about -
the beauty of all the moto series accelerators 020/030/040/060 is that you can turn portions of the CPU on and off on the fly - including branching, cache(s) etc. lots to play with...
Looking at the numbers for 060 makes me wanna cry
sell your soul to satan and I am sure you could get one =D
