RetroNinja
What app do you use for testing/measuring disk speed?
Right now SysInfo is breaking on my TF536 since I've upgrade the mmulib to 47.9. The CF drive speed is plenty fast, it's just the speed test fails. SysInfo did work fine with 46.21. You can tell a difference between the version. I believe the big reason is the MuFastROM being enabled.
There is DiskSpeed (https://github.com/erique/DiskSpeed). It says the current version is 4.3, from 2023. My download is 4.2 though and is dated 1992.
DiskSpeed v4.2 does seem to work fine on my TF536 and OS 3.2. It's just a bit too geek oriented though. It runs about 10 test variations and displays the results of each test. At no point does it sums it all up or give an overall value. You know, like SysInfo.
