Bringing dead floppys back to life :)
  • Thread starter Thread starter TroelsDK
  • Replies Replies 22
  • Views Views 738
TroelsDK
Denmark
Holbæk
Recently I have bought some games that where listed as testet/not tested and when testing them myself, they don't work :(
Getting sick of this, I decided to try and clean them myself.
This is how I did, and it should be regarded as a last opportunity! (The disk is unsalvageable and dead anyway, so why not try this) Also this is primarily for dirty disks, not for pretty looking ones with read/write errors.
I have now tried with 5 disks, and 4 works perfect now :)
1. step:
(Not always necessary!: Take off the metal cover and spring. Push it back, and gently pull it out while sliding it forward. Putting it back on is a bit more tricky, but easy enough. First insert the spring in the corner, insert the middle of the spring a little into the disk and leave the other end out. Press down on the edge of the disk to hold the spring, and connect the hatch to the metal cover. Gently pull i back and the clip should get in place.)
Carefully split the floppy from the top side. Use your fingernail or small screwdriver, and swipe it around the 2 top corners where the two sides are connected. The two small connections will loosen/break but that doesn't matter much. You can always glue them back together or just use the sticker to hold them together.
ONLY the top should be split as it will be enough to get the disk out.
2. step:
Place the disk on some tissue paper, or even better one of those cloths for cleaning TV screens, and inspect the damage (dirt & mold).
This one was quite dirty on both sides! Camera has a hard time capturing just how dirty!
3. step:
Use a cue tip with cold (or lukewarm) water to carefully clean the disk. Do not apply pressure, the plastic inside the cuetip will scratch! - Only gently rub on the dirty spots. Be careful not to bend the disk! Slow and gentle is the key! Some of the dirt may not come off but nothing to do about that. Most of it will! Do not let the water sit for too long, it will leave marks.
Added by rkauer , you can use soapy water for a better result with the mold. Just be sure to wash of the soapy water afterwards.
4. step:
Let the disk dry and inspect the surface to see what a good job you have done :)
Carefully place the disk back i the plastic case and try it out.
- If you have a can of compressed air, use it to blow out any dust from the 2 pads inside the disk.
This game was listed as "Not tested" and that would normally make me instantly loose interest, but this was a very good price for a rare game, and now I got it working so that's just AWESOME! :D
Here's a video:
[m]http://www.youtube.com/watch?v=yqv89p4Io50[/m]
Good luck! :thumbsup2:
Amazing!
I may try this on a copy of Doom I bought where the floppy surfaces are filthy.
@TroelsDK: the white spots are mould and can be cleaned with a bit of soapy water and washed in tap water after removal.
I saw this very same technique used in 5.25" floppy disks, but then they are just slapped inside the unit without the outer case to salvage the data.
Of course 3.5 disks will not work this way because the case acts as both protective and mechanical actuation of the disk drive. But just for sure remember to check the internal white pads of the 3.5" case for (more) mould before re-insertion.
Good advice :) The more details on this the better :thumbsup:
This is great news to save disks and to save software. Should be a sticky I think :thumbsup:
Very nice thank you!
Out of curiosity what game is it?
I have done this with high success rates.
It took me a while to pluck up the courage and realise that the data is inside the plastic layers of the floppy disc and not on it's surface!
Clean away, there is nothing to lose, the disks are already broken!
I love threads like this! Always nice to see people restoring things to their former glory, whether it's a CSPPC or a humble floppy disk! Thanks for sharing!
:thumbsup:
Would be great to mod/convert a regular floppy drive into a disk cleaning drive somehow.
Great trick anyway!
Funny that original disks, that would be supposed to be safely stored insise their original box, can collect so much dirt inside.
@Xanxi: that's because this is not dirt. It is mould (fungus) that develops over the magnetic coat surface (normally iron oxides).
Another one brought back to life!
On the pictures it looks dirty, but in real view it was filthy as hell!
After cleaning, both sides shined bright as new :)
See videos for result:
Before / After
was reading about the the other month, also works for older 51/4" discs, just take it out, clean, put back in another cleaner case :thumbsup:
Nice one. The cleaned one also sounds a lot better when being read by the drive.
