As I posted, I ordered my own resistor networks from a local parts supplier. I double-checked that I ordered the right part.. and then, as I opened the packet, there were two correct resistor networks and two incorrect ones (yep, two more of those 9-pinnies!
oh
As I wanted to test this thing, I put in sockets for the two 330 ohm networks, inserted the 9-pin parts and added two 330 ohm resistors and soldered an extra wire to complete the circuit. Ugly but works, at least for testing.
In the first post there is a link to german assembly instructions. What does it mean on the part "Antwort: SJ1 wurde gesetzt. Der schaltet den SCSI-Takt zwischen 16Mhz und 7 Mhz um. 16MHz sind eigentlich vom Treiber nicht vorgesehen, funktioniert aber trotzdem und ist schneller"? Google translation of that doesn't make sense. First I put the solder blod to the 16M setting (as it is in the picture) but it didn't work (boot shows grey and white screens but than halts at black screen).
Switching the setting to 7M I was able to boot my CDTV from a SCSI hard disk! The installation on the disk was a WB3.1 from an A4000 and it didn't boot correctly on a CDTV (no suprise) but I was able to access the HDD succesfully.
I put a Molex power splitter cable and took the power for the HDD from the CDTV's cd-drive's power cable. Seems to work (+5v line was around 4,92v with everything running) just fine. As I don't have any SCSI-IDE (and then IDE-Compact Flash) adapters to put inside the unit, I think I am going to put an external SCSI connector to the rear panel of the CDTV and use some external SCSI HDD box. Problem at the moment is that I don't have any extra SCSI HDDs.
Photos available
here.
Again, thanks for producing this great little gadget, Olli!
