Christmas Calendar Quiz! December #9
  • Thread starter Thread starter arnljot
  • Replies Replies 13
  • Views Views 6408
arnljot
Dad, gamer, nerd, amigian
Oslo
Oslo
The rules can be found in the first post of the first thread
Question:
What is 'ROM-WACK', and how can you easily enable it?
  • 5 points to first correct poster
  • 4 points to second correct poster
  • 3 points to third correct poster
  • 2 points to fourth correct poster
  • 1 point to fifth correct poster.
It is the machine level debugger easter egg.
Boot up with no startup sequence
Yype loadwb -debug
A "DEBUG" menu is displayed next to "TOOLS"
deguggingcan be done using a serial prot connection
a debugger, you get it by pressing the right mouse button at any Guru Meditation error.
it is accessable through the serial port at 9600
Is an Amiga debugger, you can access it pressing right mouse on a Guru message
It's the machine level debugger, you can enable it with:
LoadWB -debug
My first answer having only just found this quiz, shows how much attention I pay these days! :lol:
It is the Amiga machine level debugger. :) The ROM-Wack interface can be accessed by pressing the right mouse button in Guru Meditation.
Loadwb - debug
Boot with no startup-sequence to enter AmigaDOS and type the above command in. An extra pull-down menu will appear next to TOOLS called DEBUG. I f you have a 9600 baud (8N1) terminal hooked up to the serial port, you will be in ROM-WACK (the Amiga machine level debugger).
Others say if you are on 1.3 ROM's you can enter ROM-WACK at any guru by pressing the right mouse button, again having a serial terminal hooked into the machine as described above
Rom-wack is an Amiga Debug Interface which can be enabled by pressing the right mouse button at any guru error
Its the debugger
LoadWB -debug
then DEBUG memu
Rom-Wack is a Debugger Interface enabled by pressing the right mouse button on a GURU Meditation Screen
Apparently, you can also start it using loadWB -debug - but haven't tried that
ROM Wack is the Amiga machine level debugger.
You can enable it by pressing the right mouse button in each Guru Medidation error you encounter, but it's strickly available only on the serial port of the Amiga at 9600 (8-N-1).
The next question is here.
We had decided to accept:
Answer:
Amiga machinelevel debugger(serial debuging 9600baud), 'LoadWB -debug' can be used.
Making the amiga crash, and then use right mousebutton is not an easy way to enable it :)
