Card arrived safe and sound
Just left positive feedback.
In case anyone is interested: The card is broken, unfortunately... I burned a new EPROM, which actually initializes the card correctly, but the output is still totally blue-ish, like in the picture above. In other words, the open EPROM window is (was) not the problem.
Did lots of measurements, removed and replaced components, etc. but in the end, my guess is that the built-in DAC is
kaputt. What I didn't notice at first is that there is (was) a burnt resistor - see R12 in the picture above.
Whatever caused this, it probably sent too much current into the DAC and now it has had it... While the blue output still measures correctly against ground, red and green have way too low Ohm values against ground. But it was worth a try anyway...
