RGBI CABLE 40/80 columns (16 colors!)
Attention ... HOT NEWS! 80 columns with 16 colors!
With this cable you can make the most of the potential of your C128, but you can also use it for the C64 in 40 column mode.
What is it ?
RGBI cable 40/80 columns (16 colors!) selectable with a mini switch integrated in the DB9 male connector!
You can also use the same cable in 40 column mode with your C64 which has a video input with DIN 8 262? (no silver label)
40 COLUMNS MODE
In this mode we are in composite video signal (so you can also use it to connect your C64)
80 COLUMNS MODE
In this mode RGB signal mode with 16 colors instead of traditional 8 colors!
A comfortable high-brightness LED in the DB9 will also light up (see photo)
Why choose this cable?
The big difference between our cable and other RGBI cables for C128 are multiple:
PRICE --> 43€ + shipping
What is it ?
40 COLUMNS MODE
80 COLUMNS MODE
- Quality shielded cable Tasker (grey color) or equivalent (black color available)
- Miniaturized on-board system (with micro pcb) and with led light for operation: impossible to find better
- But the big difference is that in 80 columns mode you will have 16 colors and not 8 colors / monochromatic!
